This week we’re introducing multi-select functionality into the app, which will allow you to apply changes to, close, and export selected images within a batch rather than all images. Standard keyboard shortcuts have been added to support the use of this feature. In addition to this, we’ve also added the ability to pause and resume exports. Once the exports are completed, you will now have the option to export the same batch again with different settings if you choose to do so.
As always, a full change log is below.
Windows installer now ignores model download errors
Fixed camera profiles for Sony ILCA-77M2, ILCE-7M4, and ILCE-7RM5
Fixed Autopilot dots disappearing after changing settings
Fixed filter icons not showing until opening the image
Automatic lensfun update
Known Issues:
Under certain circumstances, images with Remove applied that are closed may cause other images to get stuck scanning or overlap the preview incorrectly
This seems to have been introduced in 2.1.0 and has a planned fix for 2.1.3
You can fix this by selected another image and discarding remove edits when prompted
There are intermittent cases where the processing bar appears frozen while exporting
A potential workaround for this is pausing and resuming the export
Has the basic functionality and quality of remove noise, sharpen, recover faces, and upscale improved much since my current 1.4.3 version?
From reading the release notes since 1.4.3 it seems most of the effort has been put into things I won’t use and little to no work on improving the basic functionality over what 1.4.3 does. With the Black Friday sale going on now I am trying to decide if it is worth buying a year of updates.
