Hi - can you please send me the original image through Dropbox? Please let me know once you’ve sent it. Thank you.
Hi Yazi. Thanks- have uploaded a crash log and 2 images which misbehave every time. Strangely however when I copied and pasted them to my desktop and re-named for ease of uploading they were fine. The 2 uploads are from my pictures folder and are still crashing. Good luck!
Several metedata and processing issues noted (Canon R3):
Autopilot Settings: Very oversharpened ISO 20,000 image
Incorrect Metering Mode: Exif shows Spot instead of Pattern
Incorrect Lens: Exif shows 100 instead of RF100-500mm F4.5-7.1 L IS USM
Strips out IPTC data for Contact and Copyright Status
Incorrect Color Fidelity Profile applied on LrC Import: R3 Base Profile instead of R3 Standard V1
Image ~2/3 stops brighter
Lens Corrections not applied on LrC Import
It’s because PNG are saved in 16 bits. Why there is still no option to save 8 bits PNG ?
I don’t understand the logic of turning on Noise reduction in Photo AI but setting the strength to zero. If the picture has no noise then you would turn off the noise reduction. I do agree that the lowest strength setting should have very little or no effect.
Yazi, is there any way to change back to dark mode for the site? I have my Windows MS Edge browser set to dark mode but It doesn’t work on this site.
Something has gone wrong since the last update (1.1.2). My Sony RAWs from the a7IV have a strong green cast after processing with Topaz Photo AI.
Before this update in Topaz Photo AI version 1.0.8 everything was still OK. The Topaz edits were very similar to the original RAWs.
I am working on a MacBook Pro 16’ M1 Max, 64 GB. System: 12.4. The Adobe Apps are up to date.
On the screenshot you can see the original on the bottom left. In the background you can see the processing in Topaz and on the bottom right the exported DNG. In Topaz it still looks good. After the export it has the green cast. Please pay attention to the snow.
Turn off the option to enable automatic dark mode color scheme.
You also need to exit and restart the browser.
And the last example. Both photos are TPAI edits from the same Sony RAW. On the left is a Topaz 1.1.2 edit with the green cast. And on the right is a Topaz 1.0.8 edit. That’s how it’s supposed to look.
This release seems to crash if there are 3 photos or more to be processed…pretty consistent for me. I shoot Fujifilm but I’m processing PNGs.
Green overlay when processing of OMSystem-OM1 RWAfiles from Lightroom. Only OM1, problem does not occur with OM1MarkIII
you have missed the point of my post. A noise reduction program is meant to remove noise, not detail. Ai photo removes detail even at the lowest setting. Denoise AI retains detail even on higher iso settings.
I have a number of smaller issues but I haven’t looked through all the forum to see if the issues that I report already have been mentioned.
Currently I am mostly working on old photos that I have scanned and have AMD 5950x, 64GB RAM with GTX 3060 Ti running Windows 11 Pro 22H2
“Sepia” tone on BW face recovery
Option needed to process (save) just one image
As I have thousands of pictures, I apricate the possibility to batch process and then looking through the final result whenever they are ready. If I find that some of the photos are not good, typically face recovery has to be adjusted some way, I cannot just choose one picture and then process that one only -
Switching between filters should happen instantaneous once applied
If I want to see the effect of a small adjustment, e.g. decreasing the applied face recovery or enabling/disabling sharpening, There is a lag and the preview reverts back to the original (noisy) picture. I would like PAI to use cache as the other Topaz products use (not working 100% though) -
Photo AI icon on taskbar disappears
At one occasion, the icon on the taskbar disappeared and the only way to access PAI was to minimize all other programs that was running (Windows explorer etc.) -
Shift of pixels when switching between before/after
Really annoying when you really what to see the effect of PAI that the picture shifts some pixels. At one occasion, left half of the photo shifted, but the right half stayed locked. When zoomed in, this behavior disappeared -
Rotation of picture not respected
Some of the scans where upside down etc and have been rotated using Windows photo viewer, but it seems that the rotation information was not used by PAI -
Random crash. Before that, the miniatures below disappeared and replaced with tif-icon
No idea really what was going on, other that I on this occasion was looking through a number of large TIF-files (100-150 MB per picture, with maybe 10-20 open in PAI) -
Glasses are added quite often even without any obvious reason
This happens quite frequently and ruins the effect of face recovery. Maybe add some enable/disable glasses (per face)?
Topaz Sharpen AI uses my Nvidia Quadro P4000 (8Gb) - 94-96% average - no matter which Sharpen Model is used.
Topaz Photo AI v1.1.2 uses GPU in a similar way but with Raw Remove Noise and Sharpen Standard modules only but with either Lens or Motion Blur modules, GPU load drops to some 0,3% making them useless on my machine.
I hoped that applying a smaller mask might help but it doesn’t change anything as if it was still calculating the whole image instead of the restricted masked area and invoking Photo AI from Photoshop on a less than 10% selection layer does not change either.
Perhaps might a future update meet Sharpen AI performances.
I did another test today with an original Sony RAW of the a7IV and a processing from TPAI 1.0.8 and from 1.1.2. The error is reproducible. The source of the error is an update after 1.0.8. Unfortunately I did not have time to test 1.09, 1.1.0 and 1.1.1.
In 1.0.8 the colours were similar to the original RAW. I was able to apply my usual presets. Unfortunately, in 1.1.2 there is not only the green cast, but also a colour shift that is so large that I can no longer eliminate the difference with the colour sliders. My presets no longer work here either. Without retouching, I cannot correct the error.
The colour error only occurs after the export from TPAI. In the preview during editing in TPAI everything still looks good.
Unfortunately, Topaz Photo AI is not usable for me in the current version.
Please let me know if you need the original RAWs/DNGs.
I am attaching 3 photos where I have set the sliders in Camera Raw all identically to show the difference in version number. On the left in Camera Raw is 1.1.2 (first Picture) and the one in the middle is 1.0.8 (second Picture) and on the right is the original Sony RAW (last Picture).
Feature request for the development team.
The subjects in PhotoAI are really well detected in general.
As Mask AI is no longer updated, a really useful feature would be to enable a mask export from PhotoAI. That would be so useful when you need a cut-out as it’s already well detected.
