PAI 1.0.5 Standalone. Win 11 Pro. Processor = Auto (all specs of mine above in earlier posts)
I tried/posted rpt of experiences with CR2 raw images (single & batch) in A.P. in the past 2-3 days.
Today I tried a Sony ARW raw batch to see if it was the brand of raw that was the issue. It was not a branded raw images issue.
The issues are with PAI coding and are consistent across raw images I ‘try’ to process using PAI 1.0.5 Standalone. I reported the problems that developed in the 1.0.5 rel. Ps Plugin separately above…
Issues that are Repeated Using ARW Raw images on A.P.:
1- No visual images appear on the icons for the imported ARW image batch at bottom of the UI. I only see icons with symbols. That is not useful. Must see the images to be able to go back to specific images to tweak settings & to verify correct images were uploaded.
2- I get a Mismatch of settings applied by A.P. (for Sharpening) when hovering over any given batch ARW image icon at base of the UI & what is shown as selected by A.P. in the righthand Settings Panel. I’ll see a Motion model # used at bottom of the UI & it’s always the Std Model that’s active (incl. with the green dot indicator) in the righthand Settings Panel & a different value is used for Std.
3- My image that’s in the PAI workspace remains typically soft-looking. Doesn’t look like a sentient robot being (A.P.) has made it sharper (Contrasty?) or clearer (Clarity).
4- When I manually change the Sharpen setting (in the righthand settings panel) to match the setting the hover at bottom of the UI shows then I get an acceptably sharpened image (ie, if my hover shows Sharpen - Motion = 49 & the righthand panel (always!) shows Standard & I manually change the righthand panel to be on Sharpen - Motion Blur Model = 49 then the image looks processed as it should be).
Whatever is triggering Standard Model to be the std A.P. setting in all instances (including Single & Batch image processing) is what’s preventing the images from being processed/sharpened correctly. I don’t program. I can only use logic. It seems like some “If, then…” parameter is screwed up. So far, , I am not seeing the same type of issue with Denoise - it clears the noise and the settings are in sync from batch thumbnails (bot. of UI) to righthand panel.
Latest Snips from Today’s Test Using Sony ARW Raw Images (in batch):
A.P.s Current Mismatch Settings Effect - Sharpen Motion Blur Model (base of UI on Batch Thumbnails) & Sharpen Std Model in Settings Panel —> Produces Blurry Processed Preview
Manual Override to Make Settings Match As They Should (i.e., Motion Blur shown in ARW thumbnails manually made to show in righthand panel to override the “Std” A.P. generated) —> Image Preview Looks Clear and Acceptably Sharpened:
