I have trouble with all the aspects of interfacing LrC and Topaz Photo AI. I sent a support request with this text on Sunday - but no reply from TOPAZ yet.
Mac OS Monterey 12.5.1; Mac M1 Ultra / 64gb / 1TB storage
Topaz Photo AI download file :: TopazPhotoAI-1.0.0.pkg
LrC 11.5, Mac
I have no trouble cycling through Sharpen and DeNoise - the interface for those products works perfectlyâŠ.so this is the basis for my comparison to TopAz AI.
I typically do some into editing in LrC for tone and then do an âEdit in sharpen AIâ where I complete the editing adjustments and then return the image to LrC and all that cycles perfectly - leaving me with a TIF aside my original file. I have Sharpen, DeNoise, Giga and Photo AI defined as external editors, TIF/16-bit.
None of this works properly in Topaz AI.
There are two workflowsâŠ
Setting up the Edit In workflow - it does not function the same way as the others as a Plugin. The PlugIn is installed correctly and enabled in LrC - I can reveal it in Finder, etc. the transfer to the PlugIn seems to work okay and it creates a TIF transferring out of LrC - but the PlugIn does not function as a Plugin - it wants to make a further [Save Image] with the module names appended to the file - now creating a 2nd TIF. You have to EXIT the PlugIn using [Close Window] but it does not terminate so you have to close it manually. The newly created TIF file is not auto-imported back into LrC - instead you have to go chase it with a Synchronize Folder and import it manually. Now you have the original file (e.g. raw), the first TIF and the final TIFâŠâŠtypically I deleted the 1st TIF as it is totally redundant.
In the alternate workflow, use LrC Menu | File | PlugIn Extras | Process with Topaz Photo AI âŠ. the process seems to work as intended - and this produces a DNG file as output. However, any edits done via LrC prior to invoking the PlugIn are not retained - this could include Auto Exposure adjustments and Auto levelling and any minor color grads - so these have to be completed or re-done again on the returned file.
Finally, I was able to cycle ORF raws from my OM-1 without difficulty - but when I tried similar round-trips with HEIC files from my iPhone 13 Pro Max, the returned HEIC files were flagged by LrC with a black exclamation point - and marked as un-readible.
In closing, Topaz AI does not have a Preferences panel and there is no check for updates within help. These capabilities and services need to be added so that all the modules in the suite have a similar UI and UX.
One other solution I have found somewhat workable, I have opened and edited the image in LrC and then passed it to PS; duplicated the layer and invoked Topaz AI as a PlugIn on that layer - that seems to work fine (except I cannot resize the image with this workflow and must do that separately). that creates a PSD out of LrC and returns a PSD - multi layered and a big file.
Jim Camelford
toronto - Wed Sep 21, Sunday Sep 18
