I am having an issue when I go from lightroom cc or photoshop to photo ai. When I try to save the file back to lightroom or photoshop I do not get a renaming option. It just gets saved as a dng. When going directly into photo ai I get the option to change the file name.
That is by design. You are editing the file using TPAI, not exporting to a new file location. This way PS picks it up inside the editor without needing to open the image and copy its contents back into the file you’re working on. For lightroom it should be creating a copy within LrC itself that then gets modified - unless you specifically tell it to edit the original. That copy then gets added to the catalog for you to continue editing or categorizing after finishing with TPAI.
I can confirm PAI works with spaces in the file name under macOS Ventura, FWIW.
As for the spaces, it’s usually Windows that has problems with that, not Macs, so that’s interesting. I DO know PAI doesn’t like “?” in the file names, it will refuse to open them.
There appears to be some who do not play with programs and the YouTube does not cover to much of the starting part. In the auto part you can also select face or landscape and also sensitivity, for landscape night go to max.
Also it is not good to do much in Lr, Color profile (like portrait for night), Lens Correction selection,All not able to select after results and Temp Picker, as well as whites and darks control to get rid of the dark blues and whites red
After is Noise, Sharpen, Recover faces (if needed) and you can select faces if one is missed, then Enhance Resolution (that in Sharpen takes time and puts a lot of load on a computer) all of which have the same options in the seperate programs. Added is Upscale (Gigapixel) (New in Lr also) that you can select 1x, 2x, 4x, MAX, BUT you can type in one of the blocks MP amount number you desire for what you need as an output.
The Pièce de Résistance is the speed and non loading on your system. And after, playing with the clean image that can be adjusted in many ways to bring out shadows of night or reducing highlights of day as well as adjusting exposure, contrast and even some clarity and texture and others.
The results allow editing of a clean image for brightness and shadows with less noise mainly none.
Also if you do bracketing you can do the pre editing of each with syncing then goto edit in Photo AI and each in line adjust Photo AI settings. The results of each will be sent back to Lr and doing a HDR of all will give a great image. Night Milky Way images even old will have hot (red) and dead (white) pixels removed that result from bracketing and camera NR is disabled just go to max on Noise. The Sharpen will get rid of the painting look and more realistic image.
I have played with some old images from 2005 using point and shoot cameras and early Canon T2i of '10 to '14 and all look like a 100MP camera results.
Today it is software that makes a great image. I have used Topaz from the beginning it came out and each time an update was greatness. Yes a camera get the image and settings have to be good to start with but if a bright day and a white swan settings cause dark shadows so software is needed to bring out. Night captures using high ISO’s need software to clean up. Photo AI gives a great starting place.
I agree that manually being able to select faces would be great. Adjusting the sensitivity in the auto pilot does help selecting people generally. But sometime faces our getting missed, which results in some faces being much improved whilst others are low quality still. I end up having to reduce the resolution in order to even out the quality of the faces.
Any ideas what could be causing a crash of Photo AI when loading (any) image?
All other Topaz apps run fine, mighty fine now that tensor support is here, but Photo AI crashes at loading the image, it goes into “detecting subject” but no preview is visible, and crashes with no error messages at all.
Windows log of the event (reinstalled in a new directory so AI is missing in the name):
Faulting application name: Topaz Photo AI.exe, version: 1.0.0.0, time stamp: 0x63237828
Faulting module name: Qt6Gui.dll, version: 6.3.1.0, time stamp: 0x6298c3e7
Exception code: 0xc0000005
Fault offset: 0x000000000002b6ba
Faulting process ID: 0x3f80
Faulting application start time: 0x01d8cc5df880bf36
Faulting application path: C:\Program Files\Topaz Labs LLC\Topaz Photo\Topaz Photo AI.exe Faulting module path: C:\Program Files\Topaz Labs LLC\Topaz Photo\Qt6Gui.dll
Report ID: 2b5a980b-e4a3-4f92-ad34-bd27660a33af
Faulting package full name:
Faulting package-relative application ID:
Am I missing some Microsoft packages for Photo AI? It feels like this is the case somehow, any suggestions?
I’m having strange artifact where face enhancement/auto pilot on black and white/sepia low resolution photos, it is making people’s eyes slightly blue, and in some cases bright blue. In fact it seems to be making the lips pink as well.
Bought Photo AI today, but it doesn’t work. It takes forever until an image is (not) loaded. It gets stuck on “Reading Metadata” – no matter what image I’m trying to load.
I have been testing Photo AI 0.6.0 and have achieved some very nice results. Downloaded my complimentary 1.0 upgrade last night and it will not install on my win 10 computer. Plenty of mem and disc space, etc. I downloaded another copy of installation with same result. Error is that it cannot create a temporary file. Investigating that error leads me to a Windows Security finding that the program is incompatible. ?
After reading through all the comments in this thread I believe I will just wait until it is tested further and has bugs fixed. I’m happy with the 0.6.0 version I already have running on this machine.
