Hello everyone!
We have another update this week whose big feature is the addition of subject mask refinement. There are now multiple models to choose from as well as sliders to change sensitivity and softness of the overall mask. In addition to this, there are also several RAW fixes/tweaks, some UI/wording tweaks, general fixes, and some big changes internally which should help reduce memory consumption. Full change log below.
If you own DeNoise, Sharpen, and Gigapixel with up-to-date licenses then you have access to Photo AI. You will need to claim a Photo AI license by going to your account before you’ll be able to login.
This is an early access release, so there will be some issues you may run across. Issue reports and general feedback are much appreciated. If there’s a specific image you’d like us to see, you can send it to us at this dropbox link. Below the changelog are a list of issues we’re already aware of.
v0.10.2
Released September 12, 2022
Mac: Download
Windows: Download
Changes since 0.10.1:
- Added Capture One plugin for Mac
- Autopilot will now suggest upscaling on low resolution images - this can be turned off in the new “Autopilot” menu bar
- Viewport now centers on a subject or face after running Autopilot
- Fix metadata (including colorspace info) being lost when using external editors on non-RAW images (including DNGs)
- Fix photoshop plugin not always replacing the old one on Mac, causing crashes
- Fix some metadata tags being missing when saving DNGs
- Fixed color correction issue after enhancing
- Fixed Autopilot re-processing after changing subject feathering
- Fixed side-by-side view not centering the preview correctly
- Increase network timeouts for model downloading on mac
v0.10.1
Released September 9, 2022
Mac: Download
Windows: Download
- Fixed some grayscale images coming out skewed
- Fixed Lightroom Classic plugin sometimes giving an error and/or not importing the file into the catalog
- Fixed Lightroom Classic plugin not selecting the folders of non-RAW folders after export
- Fixed Capture One plugin not installing correctly on some computers (and creating erroneous folder on those without Capture One installed)
- Note: Capture One plugin currently only installs on Windows computers
- Fixed wrong colors on images from more camera models
- Enabled the save button while autopilot is running
- Changed the saving progress bar with a spinner
- Improved installer error handling
- Disabled file associations on Windows due to it calling images “Topaz Photo AI Files” in Save As dialogs
v0.10.0
Released September 8, 2022
Mac: Download
Windows: Download
Changes since 0.9.0:
- Added subject mask refinement
- Reduce overall memory usage of the app
– Should be reduced by several GB in some instances. - Lowered threshold for face detection
– Some faces previously not detected should now be detected, but may lead to some false positives - After processing in LrC the photo’s folders will be selected
- Slight rewording in some places
- Slight changes to autopilot values
- Added 800% zoom level
- Mac installer should now allow retries of failed downloads
Fixes:
- Fixed hanging on save with some images
- Fixed issue where autopilot would return invalid values if auto masking failed
- Fixed issues with baseline exposure tag on DNG output
- Fixed cropping with various RAW files
- Fixed size of scaling buttons in some cases being wrong
- Fixed overall color cast when using face refinement and denoise together
- Fixed some issues where AI engine would not load models if first two attempts failed
- Fixed various Canon RAW files not loading profiles correctly due to localized names
- Fixed some RAW files showing flipped 180 degrees on preview and output
