When calling Photo AI 2.0.5 from Adobe Photoshop Lightroom Classic version 13 on a freshly imported Raw image, the DNG file created afterwards by Photo AI had altered colors (very saturated) plus, the previously checked ‘Enable Profile Corrections’ (under Lens Corrections) became unchecked in the DNG. I noticed that I forgot to check ‘Remove Chromatic Aberration’ under Lens Corrections. When I checked ‘Remove Chromatic Aberration’ and reran Photo AI 2.0.5 on the same RAW file and took the default Photo AI settings as before, the resulting DNG looked as expected with no color modifications and the two Lens Corrections settings, ‘Remove Chromatic Aberration’ and ‘Enable Profile Corrections’, remained checked. I repeated this behavior on several images. I had originally discovered this behavior in Photo AI 2.0.3 and did the upgrade to 2.0.5 before repeating the test; all attached files were under version 2.0.5.
Here are the screenshots
Raw image in Lightroom without checking the ‘Remove Chromatic Aberration’; note that ‘Enable Profile Corrections’ is checked:
Photo AI called via File->Plug-in Extras->Process with Topaz Photo AI. View of the before and after comparison; note that I took the default modifications by Photo AI:
Resulting Photo AI DNG after saving and returning to Lightroom; note that ‘Enable Profile Corrections’ has been unchecked and the colors are much different than the preview in Photo AI, very saturated:
Original RAW file still has only ‘Enable Profile Corrections’ checked
Checking ‘Remove Chromatic Aberration’ in the original RAW file:
Calling Photo AI again and accepting the defaults:
Photo AI DNG saved and returned to Lightroom; note that colors look as expected and that the Lens Profile check boxes are both checked:
Exported jpegs of the image before and after checking ‘Remove Chromatic Aberrations’:
Here are the Topaz Logs
2023-10-13-18-17-21.tzlog (119.3 KB)
2023-10-13-18-48-54.tzlog (119.2 KB)
2023-10-13-18-50-47.tzlog (119.1 KB)
2023-10-13-19-02-42.tzlog (18.7 KB)
2023-10-13-19-09-36.tzlog (17.8 KB)
2023-10-13-19-12-55.tzlog (109.8 KB)
2023-10-13-19-15-13.tzlog (17.8 KB)
2023-10-13-19-16-57.tzlog (110.0 KB)
2023-10-13-19-18-20.tzlog (110.2 KB)
2023-10-13-19-20-15.tzlog (110.0 KB)
2023-10-13-19-32-41.tzlog (14.8 KB)
Here is the Macbook system information:
MacBook Pro.spx (7.7 MB)
Topaz Photo AI [v2.0.5] on [Mac OS Sonoma 14.0]
