When I import my .RAF files from my Fujifilm X-H2 in Lightroom everything is ok.
When I do File > Plugin Extra’s > Process with Photo AI, it opens in topaz photo ai with increased exposure.
When saved to lightroom, increased exposure stays.
I have same issue. From Lightroom I go to file and select the plug in, do my adjustments in Topaz AI and upon saving back into Lightroom the dang file is extremely bright and can’t be saved. However if I bring into Topaz AI via “edit in” as a tiff file, do my adjustments and save tiff back to LR it is fine. Working with Nikon raw files.
@pieter.verhoeven@grant.hudson@martin.anstett@RyanMontgomery
We are working on improving our Raw handling for most cameras. At the moment, we have color/exposure shifts for cameras which we have documented and added to the roadmap for addressing.
For now, using Photo > Edit in > Topaz Photo AI for a TIFF workflow instead of Raw is recommended to avoid this color shift.
I don’t know if this will help you in any way, but I just accidently turned off my dedicated graphics card and the issue was gone. Hower Topaz was ofcourse super slow without it and when saving the picture back to lightroom I had a small blak line on top of the image.
I have a NVIDIA GeForce GTX 1650 with Max-Q Design as dedicated graphics card.
I never had this issue with the X-T30 files, only with the X-H2 files.
Please upload the files to my Dropbox so I can confirm and make a task to fix this.
You can securely submit your image(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something. Dropbox File Request
