Steps to reproduce issue:
On the terminal, I used the following command:
"/Applications/Topaz Photo AI.app/Contents/Resources/bin/tpai"
--cli
"/Users/XXXX/Desktop/test input"
--output "/Users/XXXX/Desktop/test output"
--overwrite
--format jpg
--quality 95
--lighting
--color
"/Users/XXXX/Desktop/test input" is the input folder containing input photos, this folder contains the input images, as you can see, this folder's path has a space in its path.
"/Users/XXXX/Desktop/test output" is the output folder, it also contains a space in its path.
When I launch the commad above, it showed the following error
[CLI] Invalid file or directory path:/Users/XXXX/Desktop/test
Error | Attempted to set index out of range: 0 images loaded, but setting index to 0
No valid image files passed
But everything works fine if I remove the spaces in the input folder and output folder paths. In other words, tpai doesn’t know how to deal with paths containing spaces.
Topaz Photo AI [v2.3.0] on [Mac OS X Sonoma 14.2.1]
