Topaz Photo AI 3.01 as a lightroom plugin is not usable anymore
THIS UPDATE HAS LEFT THE PROGRAM UNUSABLE AS A PLUGIN WITH LIGHTROOM…ITS NOW TAKES FOREVER TO PROCESS, GENERATE ETC …
I can’t use this anymore until its fixed. where can I download previous version which was response, relatively quick BUT reliable and didn’t hang up my compouter
I’d like to get some more information about your machine to help troubleshoot this issue would you please send me your system profile information so I can check if your computer hardware is up to date.
If you would like you can revert back to any previous version using the following link:
Topaz Labs Community Forums | Topaz Photo AI | Releases
Hi John, Thank you for your quick response.
I have included here a handbrake compressed video of my screen that includes system info, and Lightroom to Topaz Photo AI roundtrip attempt…
also included here is a system info file
A sidenote I find it works even slower on my computer on battery power vs plugged in.
MacBook Pro.spx (7.79 MB)
(Attachment Capto_Capture 2024-04-30_06-09-47_AM.mp4 is missing)
I uploaded files to dropbox
Thanks for sending the system profile information and screen recording. That was very helpful to understand what might be causing this issue.
First please make sure that you have Lightroom Classic fully closed before proceeding.
Topaz Labs Download Page
