Is this version discontinued? It is launching from Lightroom and do it’s magic, but fail to save back?
Topaz Photo AI [v2.3.2.x] on Mac
First please make sure that you have Lightroom fully closed before proceeding.
You can delete all the Topaz Photo AI.plist files. After you have done this, make sure you permanently delete them from your trash bin.
You can also restart your machine after this process.
While trying to download the new installer, I was only able to download version 2.4.2 or 1.3.12, not version 2.3.2, which I use
I don’t know why, but I get the same error message after reinstalling. It has work earlier but now only none raw processing works - annoying indeed
If you are still experiencing problems please reach out to us at the following link:
