There is something wrong. The tiff file did not get saved to the external disk when using the plug in within Lightroom Classic 13.4 on the Mac. Lightroom Classic cannot find the tiff file, when I try to locate the file, the tiff file is not on the external disk that contains the collection of photos. The original .CR3 is there, but not the resulting .tiff file.
Hi -
That seemed to work, although now the file is saved as .dng (which is what I was expecting, and it shows up in the finder and the lightroom classic catalog. I also updated as 3.04
Thanks
