hi for the last 2 months when processing pictures after a few pictures topaz suddenly drops out. I have to restart topaz to continue anyone know why this is happening,
@kevin_charles.bardsl
Yes … its frustrating … I had a total of 133 files … was processing them in a batch [RAW] prior to pulling them into LR … got a good number in … then Topaz just closed up … had to restart … and I noticed that it would process less and less … as I continued on …
Wonder what’s up with that …
What version are you working with?
Mine shows 2.4.1 [I can barely read it … but I think that’s what it said]
Jae
I have ver 2.4.1 as well and it is intermittently choking on .nef files when run as a plug-in for Affinity Photo ver 2.4x. It does not happen with the stand alone version.
@sonofjohan
David …
That’s odd because its the stand alone that’s crashing for me …
This is my 1st time running the images through Topaz prior to working on them in LR.
Normally I just do one here and there … but I knew I was going to have to adjust these prior.
This is for the Canon CR files …
Jae
