Topaz automatically cropping images
So I really do like the new interface. But I’m having a major issue. I have a photo I’m working on that is a water run off and the bottom of the photo is the “splash” of the water at the very bottom of the image. When I bring the JPG into Photo AI, the bottom of the photo is cropped by the program and the splash of the water is gone. I also can’t zoom out more than 31% regardless if I use the slider or the - sign.
  1. The original image file.
  2. The processed image.
Dropbox File Request
This topic was automatically closed after 54 days. New replies are no longer allowed.
