After I export an image from Lightroom, Topas launches itself?
How do I stop ths automatic launch?
Any help greatly appriciated.
Let’s try to reset your Lightroom plugin to try and get it working for you. You can follow the directions below to reset your Lightroom plugin:
Let me know if those steps get it working again.
Topaz Labs Documentation | Topaz Photo AI | Plugins | Lightroom Classic
Hmmmm.
I did that.
Closed LR.
Ran the installer; it offered the option to “repair” or “remove”, I chose “repair”
It seemed to go thru an install procedure for about 3 minutes and seemed to complete that successfully.
I then open LR and exported a photo (to my desktop and did not open it in Topaz) and Topaz opened in about 15 seconds and had the exported image in the window.
I looked at File > Plug-ins Extras and Topaz shows up. ( I did not open Topaz that way. Or another way.)
That is exactly what had happened before.
BTW; I find Topaz photo FANTASTIC!
Thanks
Howard
Howard Heffler
Home: 403-284-2961
Cell: 403- 804-2489
Thanks for your reply and for the feedback about the application ![]()
The file should be attached.
Thanks.
Howard Heffler
Home: 403-284-2961
Cell: 403- 804-2489
DxDiag.txt (122 KB)
Thanks for sending in that information.
I want to see if updating your GPU driver will resolve the problem, as there is a more up-to-date driver that has been released.
Please use the following link to update your driver: NVIDIA | GeForce GTX 1080 Ti | Driver Update
Thanks.
But I finally realized that the issue must be with Lightroom.
So, I found in the export window, one of the options is what to do after export.
I must have somehow accidentally ticked the “open Topaz” option.
I changed it to “do nothing” and the problem is solved.
Thanks for your help.
I could update my GPU driver anyway.
Howard
Howard Heffler
Home: 403-284-2961
Cell: 403- 804-2489
