Topaz AI keeps Disconnecting with my network storage drives
After the new Updates TOPAZ PHOTO AI keeps disconnecting with my netwroks drives as soon as i select EDIT IN TOPAZ AI from Lightroom classic it will get the file ready and move to Topaz software but then keep reading meta data until it says either file not found or network volume not found etc etc .
when i check my NAS storage it would have been disconnected and i have to click on before it get connected again. It only does when i do this way. When i move the pic to desktop and then from lightroom go to edit in TOPAZ it work, also as stand alone it works but only from when in lightroom i do EDIT IN it wont work.
it used to be fine before … not sure what is going on .
Also i dont see TOPAZ in files and folder tab on the MAC . I see if in the full disk access but not in Files and folder.
PLEASE PLEASE HELP
