Topaz 3.2.0 Edit Menu disabled (auotpilot, crop, mask, etc) with raw CR3 files
Topz 3.2.0 checked for updates and software is up to date.
Windows 11 laptop
The Edit menu items are disabled when trying to edit a CR3 file.
The only Edit menu items that is enabled is the Preferences item.
I attached a screenshot
Steps to reproduce issue:
Can you take a screen recording of this behavior so I can get the best understanding of the workflow you are trying to use to help troubleshoot?
Loom is a great free application for this: Loom | Free Screen & Video Recording
I have the same problem with a JPG file. Confused because I was able to mask a month ago. I’m on Photo AI 3.2.2, Windows 11.
Issue resolved. The Masking option on the Edit menu may work or not, but I find that I can still apply a mask. When AI completes the analysis, the option to “Remove” is also (or eventually) presented. I find it works and, with a couple of fails (on my part), works like a charm. Nice work Topaz!
