Timeline does not show full, true length of 18 fps video from stills
The full-length timeline is truncated for a sequence of still frame images that were derived from an 18 fps Super 8 film. For example: 3800 images is shown to have a full length of 10.736 seconds instead of 15 seconds. The same ratio will be exhibited for even longer sets of images.
Clicking the [o] icon, that is supposed to show the full timeline length only shows the erroneous, shorter length.
This had not been a problem when the icon was located above the timeline in version 7.0
Workaround: Add 40% more image frames at the end of your folder of images. Blank frames should be OK, since Topaz will never process them.
Thanks for reporting this. Our team is aware of this bug and looking into it.
