Still hanging - not closing
Steps to reproduce issue:
  1. Use TPAI 3.0.3 as a plugin/filer in PS 15.9, return to Photoshop
  2. TPAI is still in the list of open application and cannot be closed except for force quit
I’d like to get some more information to help troubleshoot the problem you are having.
Could you send us your computer’s full system profile?
Also if you can, please try to recreate this problem in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something. :slight_smile:
Dropbox File Request
Mac Studio_070624.spx (9.1 MB)
The system report is up - will send the log next time I see the problem.
2024-06-07-09-39-14.tzlog (107.6 KB)
2024-06-07-09-40-33.tzlog (20.7 KB)
Automate Plugin Log.txt (11.9 KB)
Filter Plugin Log.txt (9.5 KB)
lastSessionFiles.txt (22 Bytes)
2024-06-07-09-36-23.tzlog (88.6 KB)
2024-06-07-09-36-52.tzlog (62.2 KB)
2024-06-07-09-37-11.tzlog (77.2 KB)
2024-06-07-09-37-51.tzlog (69.2 KB)
2024-06-07-09-38-14.tzlog (139.7 KB)
Hi John
Problem came up again – after 4 or 5 uses of the Plugin - logs are up.
Hope it helps
Markus
First please make sure that you have your Photoshop plugin fully closed before proceeding.
Topaz Labs Download Page
Thanks - looks like the problem is solved for now. I keep an eye on it and will let you know if it comes up again.
A post was split to a new topic: Issues with Topaz Photo AI
