I’m upscaling an interlaced 4x3 DV file using iris to 1920x1440.
When running without stabilization I get about 9 FPS.
when adding stabilization (full frame 70%, both boxes for jitter and rolling shutter not checked) I get about 1 fps!!!
is this normal? on V3 it did not add so much overhead (I think it was about half speed - 4.5 fps. not sure)
but, on V3 it didn’t work - it would show good results on preview but nearly no effect on the final video! (on long videos)
Maybe you finally made it work but now its VERY slow?
my system:
AMD 7950x, RTX 3060TI, 32GB DDR5 RAM (6200, low latency)
Hello,
Could you send us an email at help@topazlabs.com with the full log files from the app?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport” file to your reply.
