Square appears after rendering
Hi everyone,
  1. I sent raw file from LR to PhotoAI using File > External Module > Topaz
  2. I cropped the zone to edit
  3. I choose : Upscale x2 + Denoise + Sharpen Standard v2
And the result is good execpt for background : some squares appears :frowning:
See capture.
Hope it will helps.
Julien
I made a new try.
If I unswitch “Upscale” the problem disappear even in the preview window.
Only the “High fidelity” Model is concerned.
I speak too quickly the result is not clean in standard mode… :frowning:
I use the last update version of Photo AI and model.
You can see squares in the background :
Can you help share the original image so that we can try to reproduce. We have a candidate solution want to test.
https://www.dropbox.com/request/jMRTcUMQDGzgXFAV7lsN
And what is you cpu and gpu and operation system?
I’m Using Macbook Pro Ventura and M1
