Using Version 3.1.2 on M1 Mac Sonoma 14.5, using .cr3 RAW images from Canon R3.
I’m having an issue as I’m adding enhancements, typically sharpening with mask adjustments. When I finish and select “Controls”, the action appears to work, but the split screen right side shows the original rather than the newly sharpened image. If I exit and restart Topaz, it will work again.
Steps to reproduce issue:
- Open Raw image in split screen preview mode.
- Select Sharpen Subject (RAW denoise has already been applied by app)
- Note that both let and right sides have the label “Original”
