Sky over sharpening
Why does Topaz sharpen everything against the sky to the extent that there is a halo around the subject - that is without the sharpening option?
I notice that the denoise also remove some texture - I can understand that it must be very difficult?
Thanks for an amazing product!
Hi, do you have TPAI 1.3.5?
Try the Strong sharpen filter, at low values, like 5 or 7.
And try the new beta denoise models, also at very low values.
Thank you - I will try that!
The Beta is working very well - thanks again!
