Topaz products are not compatible with the R52’s RAW files and no commitment from them as to when that will happen since they rely on the Open Source LibRAW, which is compiled by volunteers.
So if you want to convert to DNG you have to do it through Adobe Camera RAW, Canon DPP or other 3rd party software that does support the R52’s RAW files first. Then you can process on Topaz products.
I would like to let you know we have released Photo AI v3.3.2, which now fully supports the RAW files from your Canon R5 Mark II . You can forego the previous DNG workaround and edit the native RAW files directly with Photo AI or its plugins.
We want to thank you for your patience and collaboration while the Developers worked through adding support for your camera model. We appreciate your understanding, and we hope this new update will improve your workflow and photo editing experience.
You will be able to download this update by using your in-app update option or by using the link below
Photo AI v3.3.2 - Mac: Download
Photo AI v3.3.2 - Windows: Download
You can find a full list of changes and fixes for this version release at the following link:
