Render takes ages
  1. Render takes 10x more time after latest update with same settings.
  2. windows 10, 32 gb ram
    3.logsForSupport.zip (341.0 KB)
The logs are showing that you have a RTX 3050 with only 4GB of VRAM for the app to use. This is below the System Requirements for Video AI for the app and will cause slower processing.
With the latest update, there are some reports of slower processing that the team is looking into.
Might want to see if there is a GPU driver update for your card as well, sometimes the newer Studio Drivers can help.
