Remove tool stuck in a loop
When make selection of an object to be removed, Topaz remains stuck in the “Compiling Models” mode. I am running the Monterey OS.
@monroepsy I am experiencing the very same thing. I am running Monterey OS on a Mac mini M1 (2020).
This is a long and winding tale.
I use OpenCore Patcher which has post-install files that need to be installed in order for the Monterey to run correctly on my 2010 Mac. After emailing Topaz, I found out that OpenCore still runs without these post-install patches, but not well, especially with Photoshop.
After loading the post-install OpenCore patches, Photoshop is running exactly the same way it does with Big Sur.
I hope this helps.
Trevor
So does Topaz Photo Ai Remove now work for you or do you still have the looping and displaying “compiling models…”?
Marvin
Same problem. Hopefully, Topaz will fix it soon. They seem to be reputable company.
Same problem. This feature simply does not work on my MacBook Pro running Sonoma. Specs of machine:
PROCESSOR: 2.4 GHz 8-Core Intel Core i9
GRAPHICS: AMD Radeon Pro 5500M 8 GB and Intel UHD Graphics 630 1536 MB
MEMORY: 64 GB 2667 MHz DDR4
macOS: 14.2.1 (23C71)
If you are still experiencing problems please reach out to us at the following link:
Topaz Labs | Support Page
@matthew.stough
@monroepsy
All looks well John.
Thanks for all your efforts
Trevor
I reported the situation resolved for me in the release that followed my report. Thanks for following up.
Peace
Marvin
It’s been a quite a while since I reported it. Sorry, for not communicating to you that it was resolved.
