Remove tool does not work
After starting the Remove Tool, the circle that is supposed to mark the elements to be deleted sometimes appears. But the circle does not turn red and nothing happens. Everything worked with the pre-previous version. I use Topaz AI 2.4.2 and a Windows computer with Win 11
I have the same issue. Often it does not work at all. If I do get it to mark an area to remove, it is not removing anything. It used to work well. I am using 2.4.2 on Windows 11.
@rpkraemer @hmtimm
Topaz Labs | Support Page
