Regarding batch processing of videos with different frame rates:
For instance, let’s say we’re upscaling three videos with frame rates of 24fps, 29.97fps, and 60fps. Naturally, each video should retain its original frame rate. However, when the processing begins, Frame Interpolation is automatically enabled for the second and subsequent videos, forcing them to 24fps like the first video.
I recall that previous versions didn’t have this issue. How can we ensure that each video is exported with its original frame rate? If this is a bug, I strongly urge you to address it.
Currently, I can think of two workarounds:
  1. Configure settings individually for each video.
  2. Pre-sort videos by frame rate and process only videos with the same frame rate together.
While these methods might work for a few videos, they’re impractical for my situation where I need to process hundreds or thousands of videos. I’d prefer to avoid these time-consuming approaches.
Could you please provide a more efficient solution or fix this issue in a future update?
Mac Pro 2019
Sonoma 14.6.1
Mem 48GB
Video AI 5.3.2
Thanks for reporting this! We are aware of this bug and the team is working to resolve this in a future update.
In the meantime, I would recommend using one of the two workarounds mentioned
