Recover faces seems to work well for removing noise but leaves the rest of the image bad.
So deselected “recover faces” and just turned up the denoise slider.
Does not seem to add and reduction of noise even when selecting Extreme with the slider all the way up.
Windows 10
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
Dropbox File Request
