1.Noise like afterimage
2.DxDiag.txt (103.2 KB)
3.I use CLI.
"C:\Program Files\Topaz Labs LLC\Topaz Video AI\ffmpeg" -y -i %1 -sws_flags spline+accurate_rnd+full_chroma_int -filter_complex tvai_up=device=-2:model=prob-3:scale=2:compression=0.2:details=0.2:blur=0:noise=0.1:halo=0:preblur=0,scale=out_color_matrix=bt709 -color_primaries 1 -color_trc 1 -colorspace 1 -color_range tv -an -c:v prores_ks -profile:v 3 -vendor apl0 -pix_fmt yuv422p10le "%~n1.mov"
Note the noise in the green background.
The temporal noise processing has failed, and the afterimage of the red costume in the previous frame appears to be affecting the later frames.
Original Frame 1
Filter Frame 1
Original Frame 2
Filter Frame 2
When I posted the image, it was converted to JPEG and the noise was hard to recognize, so I am uploading a PNG.
org,enc.zip (3.6 MB)
