Prores not importing in Adobe Premiere
I’ve tried all the prores codecs but Premiere takes minutes to simply import the file, and then only audio is available. What’s going on? The other video exports don’t work in Premiere either. What am I doing wrong?
Can you share the app’s logs, the input video, and the exported video for testing?
  1. To gather logs, please select Help > Logging > Get Logs for Support and attach the zip file to your reply.
  2. The original input video
  3. The exported video
Also, which version of premiere are you running?
Submit File to Dropbox
