Program is so Slow its not usable
I opened the program today and it was so slow I closed it, rebooted my computer and tried again. It still wouldn’t work so I downloaded the latest version 2.4.1 - it again, took forever to open the photos and would not process them. I deleted the application completely and downloaded the old 2.3.2.
It took 1 min 51 seconds to open one photo. It then took over 3 minutes to process it with sharpening and noise reduction - I don’t know how it looked because the preview would not update.
I had to wait over a minute to change the zoom magnification.
I then went and re-downloaded 2.4.1 and it again took forever to open the photos and I don’t know if it’s processing them.
I have a new MacBook Pro - Apple M2 Pro with 16gb of memory - I had no issues last week.
Please help - I rely on this software.
Steps to reproduce issue:
  1. Step 1 - try to open image and wait
  2. Step 2 - try to process image and wait
  3. Step 3
Topaz Photo AI [4.2.1] on [Mac]
Same issue here since latest update. Not usable anymore to process images.
I guess this constant preview update during zooming steps doesn’t help either…
Topaz Labs Download Page
This worked for me - its lightning fast now and I love the 2.4.1 version.
Thanks!
Hi John, could I please get theses instructions, but for windows, not mac.
If you are still experiencing problems please reach out to us at the following link:
Topaz Labs | Support Page
