Program is running very slow
After the new update the program is extremely slow. When I say slow it is slow, taking more than five minutes just to open. Then another five to render and so on and so on. It will take 45 minutes to an hour just to work on the image. With my workflow it use to take me less than five minutes. Everything is updated so what is the issue?
There are maybe some old files on your system, reach out to the support on the main site.
You can securely submit your files(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
MacBook Pro, M1, 8 GB of Memory running Sonoma 14.2.1
Topaz Labs Download Page
If you are still experiencing problems please reach out to us at the following link:
Topaz Labs | Support Page
