The most recent version i.e. V3.0.0 is running way slower on my W10 machine than the previous version. There doesn’t seem to be much point in giving you the specs of my machine as by reading through the various postings listed this now seems like a fairly common problem .
Thanks John.
I much appreciate it.
Regards,
-AR.
I have the same issue with Windows 11 on a new laptop. Did not have an issue with V 2.3.2
Not that I am overly aware of. Most files would zip through in maybe just over a minute using the pre-update version. Doing the same simple denoise only in PAI 3.0.0 might now take 10 to 30 minutes.
I don’t have that kind of time frame. Just tested an image an from start to finish it’s about 48 seconds.
My slow down comes in using a brush to change a subject
