Processing speed goes down after certain number of conversions
Hello,
I am currently trying to convert a series of videos. I notice that after one or two conversions of videos of same resolution, and similar lengths and bitrate (around 15 min) using the same settings each time (for reference, upscale to 4K from 1080, progressive, Theia Detail, Sharpness 40, Grain amount 5, size 1), the processing speed goes down from initially 0.3-0.4fps for the first video I work on to 0.1fps for the next (or two afterwards) and never recovers. Even after restarting the application the processing speed does not return to around 0.3-0.4fps. The only way to get this higher speed is to restart the computer, reopen the application, and apply my settings to the video then I get 0.3-0.4fps. I would prefer not to have to restart my computer so often.
I am using the following:
  • Topaz Video AI version 3.1.6
  • MacBook Pro Apple Silicon M1 (2020)
  • 16GB RAM
  • Mac OS Ventura 13.2
Performance Settings:
  • Use GPU (Apple M1)
  • Max. 100% memory usage
  • Max. 4 processes
  • Low power mode setting off
Is there something that can be done or needs fixing such that I don’t have to keep restarting my computer every time I want to convert another very similar video to one previously converted? The fact that a computer restart rectifies the issue suggests maybe something is possibly not being ‘reset’ or ‘cleaned up’ after each conversion?
Thank you for your attention.
I am going to reply in this post, because I am encountering the same issue, but from a different cause.
As I have V2 of the application still that I use, anytime I open the V2 and then (after closing V2) and opening the latest V3, V3 will process at 1/4 of the speed.
I can do multiple tests and an upscale in V3 with no issue, but the second I open V2 it kills V3 processing time, regardless of restarting apps. It does not cause any slowdowns in V2, it keeps going as normal.
Like above, only restarting the PC fixes it, so anytime I use V2 at all, I have to make sure to restart the PC before trying to use V3 again.
I wonder whether this is also linked…I have noticed that when I receive an ‘Out of Memory’ error from processing a video, trying to process another less intensive video produces ‘Out of Memory’ without even trying to process. Restarting the application does not resolve this. I actually have to restart the computer again! And then I can process the aforementioned less intensive video without problems. Is there some missing clean-up logic?
@ebee Thank you! We are looking into this :slight_smile:
