Problems with running the programm while Nvidia G-Sync ist activated
Version
Topaz Photo AI [v2.1.3] on [Windows]
Steps to reproduce issue:
Activcate Nvidia G-Sync and open Topaz Photo AI.
Issue:
While the Nvidia G-Sync technologie ist active the entire screen begins to flicker when I move my mouse inside the programm.
When I disable Nvidia G-Sync the programm runs smooth and fine. The behaviour is only occuring on Topaz Photo AI. I possess the entire Topaz series and it only happens to Photo AI.
I tried even to disbale Nvidia G-Sync in the Advanced settings inside the Nvidia control panel but it does not work.
3
kind regards
Dominik Schreiber
I always run with G-Sync on, and have not had this problem.
Seems to be more for gaming than photo editing?
Not sure if I have it activated on my card. I don’t get any flicker in PAI. Do you have the gaming or studio drivers, set on your gpu card?
I have changed my driver to studio, which seems to have fixed some issues with Topaz but it does run slower.
Hey,
thank you all for your replys. I have indeed the Nvidia Gaming driver installed and Nvidia G-Sync enabled beacuase I game a lot. I can deactivate Nvidia G-Sync for using PAI. If I do so I have no problems at all. The strange thing is that it only happens at PAI.
Does anybody have the same issue or any suggestion of what I can try next?
I just tried to record that flicker in PAI but it were not recorded. Wierd.
