The Remove Object tool in Photo AI is not intended for full background removal. Instead, it’s designed to blend smaller removed areas with the surrounding image. For complex background removals, this tool may not deliver the desired results, as it’s best suited to removing specific objects and filling in with surrounding textures.
If background removals are essential, we recommend using a dedicated tool designed explicitly for that purpose, as it will provide a more precise and faster outcome.
Thanks for answer, but I see a problem, when you select the background it get completely orange that’s mean you cannt select small part of it. In fact its not so useful as mentioned by other customer! It would be good to just have a pencil small and large till the limit of efficiency it can assure.
And more when you start removing, it fill up a big part of memory and block my PC. Too heavy even with 32 Go!
Hi i hope you can give me an answer for my last question: when i want to mark a smaller part to remove, the red brush doesnt follow the mouse move, instable befor to stop, but its difficult to be accurate with the covering of the part to remove! And when i start the removing, it takes all th memory and dont finih to remove, i have to stop the process if i want to work again with Topaz AI.
Hi, i send you the 7th nov my Dxdiag on your Dropbox, did you receive it? Did you already look at it and can you give me some information concerning my problem?
