Problem rendering/exporting with Gaia Model
Whenever I am trying to render or export a video using Gaia it throws an error instantly.
Other models are working fine, I am trying to upscale a 1280x720 anime footage to be upscaled using Gaia. I am using Topaz Video AI 5.4.0.
Screenshot:
Logs:
2024-11-24-17-37-29-Main.tzlog (88.2 KB)
logsForSupport.zip (14.6 KB)
Could be a vram issue. I would suggest putting Max processes on 2 (if it is currently on 1) and try again (also select your gpu if it’s on Auto):
If that doesn’t work, then lower Max memory % (try 50%) and try yet again.
Other models work fine, Rhea, Rhea XL they use way more vRam than Gaia
Have you tried adjusting the settings as suggested?
I reinstalled and it works now
