I have a few videos I’m trying to upscale and for whatever reason, the frame rate on some of these videos is showing 120FPS even though they are clearly 25-30FPS videos. When trying to double the frame rate, it comes out as a jittery mess. Is there anyway to get the original video to properly report its true frame rate?
I think that would solve my issue when trying to upscale and convert to 60FPS.
I can only suggest using a tool like MKVToolNix to multiplex the video and audio into a new container. This is a fast process that doesn’t reencode anything.
Thank you for this, the tool worked but created a new problem…it rotated the video upside down upon export to MKV using the tool…no idea why that happened but is there anyway to force it to not rotate?
I’m having the same problem, specifically with Elgato’s Video Capture software. I’m able to remux using Lossless Cut and the framerate issue in TVAI resolves itself, but it would be nice to avoid the extra step.
