Presets are a valuable addition. However there is an issue, I would like to mention:
When opening an image in Photo AI, the Auto Pilot makes its suggestions. If you then want to apply your preset, you will have double entries of the enhancers. So, I suggest to add the option of removing the entries from Auto-Pilot when applying the ones from the preset. It would only need a dialog whether you want to replace the entries, when using the preset.
Steps to reproduce issue:
Topaz Photo AI [v3.x.x] on [Windows/Mac]
