Used save as preset function.
Upscale, low resolution settings.
Saved the preset and the JSON is in the Preset folder, but preset never is in the menu to use and I cannot select any of the presets I created ( 2 ).
2024-06-28-14-50-23.tzlog (372.1 KB)
2024-06-28-15-11-43.tzlog (30.9 KB)
2024-07-02-20-02-23.tzlog (170.0 KB)
2024-07-02-20-11-44.tzlog (443.1 KB)
2024-07-02-20-16-43.tzlog (70.4 KB)
Are the Preset options present when you click on Add Enhancement for the image you are working with while using Topaz Photo AI?
Here is a screenshot example of where to find this option:
Yes, they are there. Last time i used it they were in the context menu when I right clicked. Must have been in the update notes and I just didn’t see them. thanks for pointing that out!
system
(system)
Closed
September 1, 2024, 12:28am
4
