Preset for second enhancement not restored correctly
  1. The bug / behavior you have encounterer
Create/update a preset with a “second enhancement” with “Enable parameters” and “Mode: Manual”.
Apply the preset to a video
The mode of the second enhancement is set to “Dynamic” instead of “Manual”.
The values of the various parameters (Fix compression, Improve detail,…) “seem” to be the one of the preset.
Change the “Mode” of the “second enhancement” to “Manual” (as it should have been) and try to export the video: The metadata of the video show “relative to auto” mode (contrary to what is in the gui)
Change back the “Mode” of the “second enhancement” to “Dynamic” and then again to “Manual”. Export the video: This time, the metadata show “manual” for the second enhancement.
Change the “Mode” to “Dynamic”: All the parameters reset to 0
  1. Your system profile
Windows 11. Topaz Video AI 7.1 (but was happening also in 7.0.2 and perhaps earlier)
I will run some tests to try and duplicate this situation and share the results with the dev team for their investigation.
