Only 2 applications remain to be updated, JPEG to RAW and Adjust AI. The rest work on Big Sur so it is always good to check the facts before posting.
I was referring to JPEG to Raw specifically. But âonly twoâ when theyâve had so much time to fix paid for software is still unacceptable.
Do you have a date for releasing a new update to make it work this, or itâs unfixable?
This took more than suppose to be, itâs like no one is working on the problem or perhaps my second thought Topaz going to remove both âJPEG to Raw & Adjust ALâ
I like Topaz never tried any other software/application than these brilliant sets, so probably going to search for Alt just for temporary while you fix this.
Thanks
The most likely answer is that the only programmer they had for these two left a couple of years back, and no one else has had the time to go back through their undocumented code to figure out whatâs what enough to do any updates on them.
Just raise a support request at the main website as they have said they will update the last 2 apps in time, the rest of the replies here are just conjecture as everyone else is a user and have absolutely no idea.
What if I just bought a MAC with Big Sur already installed. Adjust (which I paid good money for) is now useless.
How soon will those programs be updated to work on the updated Big Sur?
So Adjust was supposed to be ready in Feb. Itâs now basically May. So disappointing as this is one of the programs i use the most and itâs been worthless.
And over 6 months later, both Adjust AI and JPEG to RAW still wonât run? Seriously?!
Itâs bad enough that Topaz Labs seems to be ignoring that Apple Silicon is the present and future of computing, but to not even get these two apps to run under Big Sur isâŠwellâŠshameful.
I just purchased Adjust AI tonight and am running Big Sir. No where did it say that it doesnât work before I purchased it. I had to search out this community to find this post. Not sure how to get help or a refund. A little frustrating to say the least.
Refunds come from the Topaz Labs website, raise a support request there.
