The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
I am not 100% sure what changes may have occurred but it could have been some settings on either your machine or the application. Regardless I am glad that you are able to receive the proper edits you want with the application
