I loaded a JPEG photo (taken with Olympus Digital Camera TG4) into Photoshop and then applied filter Photo AI.
The photo doesn’t load correctly as the screen is white but it seems like the background processes still run.
Would you mind sending me the original image file to get a better understanding of the problem you are having with this particular type of image? You can securely submit your image(s) to my Dropbox using the link below.
Thanks for sending in that file. I was not able to replicate this issue you are reporting however I re-examined your dxdiag file and it looks like we can try to update your GPU driver to see if this would resolve the issue.
