Opening a file from Lightroom via plugin extras-process in Topaz photo AI the progress dial stops moving. Works O.K. if just shsrpening.
This started after updating to Photo AI v2.0, still the same with v2.0.2
Running Windows Ten on AMD Ryzen 7 with Invidea GE Force GTX 1660 TI.
As a follow up the files I am processing are .orf from OM sysrems OM1 amd .nef from Nikon Z7ii. If I right click a file and choose ‘Edit In with Lightroom adjustments’ it works O.K. with the Tiff file that is generated.
How do I go back to a version before the 2.00 update?
