PhotoAI freezing after exporting changes to Lightroom Classic. Have to force quit every photo.
Steps to reproduce issue:
- Step 1
- Step 2
- Step 3
Let’s try to reset your Lightroom plugin to try and get it working for you. You can follow the directions below to reset your Lightroom plugin:
Let me know if those steps get it working again.
Topaz Labs Documentation | Topaz Photo AI | Plugins | Lightroom Classic
If it does not, open Topaz Photo AI, go to the menu bar on the top, and click the ‘Help > Open Log Folder’ menu option. Please send in all the files located in this folder.
You can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something. ![]()
2024-06-07-19-39-6.tzlog (126.0 KB)
2024-06-07-19-47-34.tzlog (122.9 KB)
2024-06-07-20-09-31.tzlog (93.9 KB)
2024-06-07-20-11-32.tzlog (21.0 KB)
lastSessionFiles.txt (70 Bytes)
It is working better, however it still freezes, just not on every photo. Also, when processing the edits it is not showing the file size. I sent the logs to your drop box.
First please make sure that you have Lightroom Classic fully closed before proceeding.
This did not work. It’s freezing on every photo now.
Can you try this unreleased alpha version and let me know if you still get this issue:
Topaz Photo AI Alpha | 3.0.0.0
If the problem continues, can you send us new logs?
