I run Photo AI from Photoshop - both programs are up to date with updates. I can manipulate Photo AI, and when I go to export to Photoshop, the program freezes and will not export.
Same issue here:
I am running 2023 macbook pro with 36gb of RAM.
Disable any antivirus, firewall, VPN, or proxy software that might be active on your computer. These tools sometimes interfere with the installer’s ability to download the model files.
Ensure that the Topaz Photo AI installer has all the proper settings in your system by going to your Mac System Settings > Privacy & Security tab and scrolling down to the security section. You will want to make sure you have ‘App Store and identified developers’ selected | MacOS | Example of Proper System Preferences
