Photo AI Adjust Lighting creating color cast
When using the new version of Photo AI the Adjust Lighting module appears to not be working. I get a color cast over the entire image.
When I save the image back to Lightroom 6 it looks like this.
I have the same issue when using Photo AI by itself. I have no issues with it crashing or with the other modules. The Color Balance module will work if I do not use the Adjust Lighting module. I have changed the AI Processor from Auto back to the GPU and had the same issue. I also uninstalled Photo AI, downloaded the full version from the website and reinstalled it. Still have the same issue.
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Topaz Photo AI [v2.0] on [Windows 11]
I am seeing the same issue - I shoot real estate and interior shots with any white turns to a blue color cast as soon as Adjust Lighting or Balancing Color is applied. To remove the color cast, the adjustments have to be set to zero, which kind of defeats the purpose.
@Scorpio71GR @bob-3297
Could you share the images which are having this issue? I can try to reproduce and share the results with my team to fix this.
Dropbox File Request
Hi,
I just uploaded an image.
HaVa Great Day!
Bob Taylor
Havadrone Photography
www.LakeHavaDrone.com
928.275.2741
Thanks for sharing the file Bob. I was able to reproduce the issue and made a task for my team to look into it.
