Pause/Resume is still a problem here
Since no one recognized my post i post a link to that here.
Pause/Resume is not working when using Apollo in order to raise the frames per second.
This error is in version 5.3.6 and maybe before also and up to 7.0.0
So if you use Apollo Version 8 to give more frames per second it is working fine.
But you cant use the Pause/Resume feature !!!
If you used it… from that point on the video you just see the the same frame without any motion…so the video track is broken.
Would be nice to see a fix on that…
The topic: Pause/resume threw away 17 hours of rendered footage
created on Dec 2024
closed on Mai 2025
has still status “investigating”…not solved !!!
This issue is still being investigated and worked on by the team. Unfortunately, it is taking longer to find the actual cause and fix the issue to have some models working again as intended with this feature.
